Domain not published for one of a survey's select_one questions
380
02-06-2025 06:13 AM
HanliePetoors
I'm working in ArcGIS Enterprise 11.3 and Survey123 Connect 3.21.62.
I have a survey with several select_one questions and all of the domains are present in the service except for one. This question has no choice filter.
A selection of the entries in the choices tab:
The question in the survey sheet:
And the result in the feature layer fields:
Does anybody know why this is happening?
Thanks
Hanlie
Lei_Liu
Hi HanliePetoors,
Thank you for the information you've provided. Unfortunately, I'm unable to reproduce the issue you're experiencing. Would you mind sharing your XLSForm so that we can investigate this further?
Lei
HanliePetoors
@Lei_Liu  thanks for looking at this. It does seem a bit arbitrary
The XLSForm is attached.
Regards
Hanlie
Lei_Liu
Hi HanliePetoors,
Thank you for sharing your XLSForm. Upon reviewing your form, I noticed that you have set the polygon_quinary_catchment field as a text question. This explains why the domain values are not displayed for that text question.
I attempted to replicate your issue by changing the text question into a select_one question as demonstrated in your screenshots, using ArcGIS Enterprise 11.3 and Survey123 Connect 3.21.62. However, I was still unable to reproduce the issue. The domain values appeared correctly, as shown in the screenshot below.
For further detailed investigation, I recommend reaching out to our Esri Support  team. They will be able to provide comprehensive assistance for your specific case.
Lei
HanliePetoors
@ Lei_Liu thanks for the reply.
You are correct I could create the domain by changing the type column. However I'm using the web form in an EB app in a survey widget that copies the quinary catchment from the map to the survey form. I find that the quinary catchment does not get copied if the field is a select_one.
Would you mind checking on your side if the domain is created for the species field? Because in my implementation it is not despite select_one being specified and the drop-down list shown in the web form.
Thanks for looking at this.
Regards
Hanlie
