Does body::esri:visible support image questions?
1478
09-27-2022 06:30 AM
TL2
Does body::esri:visible support image questions?  I am using 3.15 and it seems like it doesn't, but should.  Is there a work around?
TL2
I actually have an account and reported the "bug".  According to ESRI it is not a bug.  But I will try the group idea.
https://doc.arcgis.com/en/survey123/desktop/create-surveys/xlsformexpressions.htm#ESRI_SECTION1_7FC9...
Image and audio questions do not support being hidden by the body::esri:visible column.
Richard_Purkis
@TL2 I can reproduce the issue. The blog article includes image questions in the example so I am confident this is a BUG. My recommendation is to raise this with your distributor's support team
LaurenceTait
Amazing that years later ESRI still hasn't addressed this bug despite the functionality becoming standard: https://community.esri.com/t5/arcgis-survey123-questions/bug-body-esri-visible-not-working-for-image...
You'll have to use the same solution we've all been using for 2 years - put the image into a group and hide the group.
The abstruse and intrusive process that ESRI has in place to report bugs, requiring users to have their IT department  set up a special account and then provide ESRI with personal contact information means that the odds of anyone actually reporting a bug like this is small.
If the process had been set up so that bugs wouldn't have to be acknowledged, it wouldn't have been done better.
TL2
Richard_Purkis
@TL2 Thanks for posting a link to that documentation. That's the answer then 🙂
