I've updated a list of choices within Survey123. This edit is reflected in the form, however, the valid values in the feature layer do not reflect the choices provided in the Survey123 form. For example, I have a data line that was given an incorrect ID. I am trying to edit this data line in ArcGIS Pro, however the list of values does not include the newly updated list. It only gives me to option to pick from the old list of choices. It also does not let me write in a value. All other changes made to the Survey123 form (such as schema changes) since my last edit are showing as expected.
