Disadvantages in the latest version of the Survey123 app, the button to capture photos is disabled
4206
19
06-27-2024 09:46 AM
JulioDumeynieu
Dear, note that with the latest version 3.20.65 of the Survey123 app, the button to capture photos or upload an image stopped working, specifically when you want to edit the records from the inbox.
I would appreciate anyone who can provide a solution to this problem.
Stephanie_F
Hi Julio,
This behavior has been documented as BUG-000168654: Image questions in Survey123 can no longer be edited via the Inbox or when opening the app via a URL using the action=edit parameter.
I would advise reaching out to Technical Support so they can help you get status updates for the bug via My Esri.
--Stephanie
alseahawk
Seeing the same thing here.  I have a problem ticket in with Support so hopefully there will be a fix soon.
Stephanie_F
Hi Julio,
--Stephanie
RMiller
Hey, I'm just curious: Does this have to do with last night's update to AGOL? If so, when will it be fixed?
DougBrowning
MVP Esteemed Contributor
Do you have method=camera,browse added to the image question in the body::esri:style column?
Is it inside a repeat at all?
BHickinbotham
Seeing the same issue and was given the BUG number from above as well.  Since I'm waiting for my account to linked to my organization, can anyone say when the bug was first documented?
Thank you.
DanielCRS
I have encountered the same issue with a survey that had been working fine prior to today. It does look like I can see the take photo/add attachment buttons when I am trying to collect a new survey. It is only when I am working with an existing feature via the Inbox, that I encounter this issue.
I had one device working and another not working and I suspected that it was related to camera access permissions. To test it, I turned off the camera permissions on the device the survey was working on and confirmed that the picture icon with a line through it showed up. When I turned the permissions back on, however, I no longer have the ability to take pictures/add attachments.
CristianGraf
Same here. Since this morning users are not be able to add new photos on submited forms.
Survey123 app was updated automtically yesterday on iPhones and Android phones. Same issue.
On foms some have something on the ESRI parameters (action=edit), other have not.
On the left, view mode. Right one on Edit mode... same form.
Other form/project.
DougBrowning
@ZacharySutherby   heads up on this
ZacharySutherby
Hello all,
Thank you for reporting this! We are aware of the issue and is logged as BUG-000168654. We are investigating.
CC @JamesTedrick @ChrisLeSueur
Thank you,
Zach
