Disable Questions if one or the other is selected
692
6
10-07-2025 02:23 PM
SueBoelk2
Help please!
Enclosed is a form with an inspection of a dairy.
Most of it works quite well however we need to help the user avoid inadvertently clicking an unwanted choice.
Problem @ #15:
Background:
The inspector has the discretion to charge either a 2 point deduction or a 5 point deduction depending upon the severity of the violation (that is the reason for there being 2 categories with the same violations but different point deductions.) The inspector must choose one violation (either one 2 point violation or one 5 point violation).
Needed result:
If there is one 2-point deduction, then 5 and 7 point deductions will be grayed out.
If there is one 5-point deduction, then 2 and 7 point deductions will be grayed out.
No problem, this is working: If there is a 7-point deduction, then 2 and 5 point deductions are grayed out.
I am beginning to learn conditional expressions but am not there yet.
Any help is appreciated.
DeonLengton
Hi Sue
You can simply use the count-selected to check if the 2-point or 5-point deduction was done and then make the other deduction read only
For instance - the group 15. -2 pts Drug and Chemical Control -2 points
make this readonly if  count-selected(${protection3_issues})>0
Then for group 15. -5 pts Drug and Chemical Control -5 points
make this readonly if count-selected(${protection2_issues})>0
DeonLengton
Hi Sue
SueBoelk2
Thank you Deon! Will work on implementing this solution!
Neal_t_k
MVP Regular Contributor
I am not sure in the format you have that this will work as you explained.  When testing with @DeonLengton's suggestion,  it needs an 'or' to to trigger for the 3 questions scenario.  I kept getting a cyclic dependency error when filled in for more than one question.
Is it possible to add a prior question with relevancy for those three groups.  This would solve the cyclic dependency.  See attached for example
DeonLengton
Hi Neal
Yes if you try to do the readonly setting on the multiple choice fields then you will get a cyclic dependency error. That is why i put the readonly setting on the groups - not on the multiple choice fields.
Hope that helps
Neal_t_k
@DeonLengton good call, I missed that in your explanation.  You still do need an 'or' but using it on the groups works.
I would still suggest considering the solution with relevancy I supplied above.  You could do a note question that explains the options prior to the type selection.  The benefit of this solution would be then you are not showing them non-relevant information and shortening the form.
SueBoelk2
Thank you for your help Neal- good to know about the cyclic dependency and why it was appearing. Thanks again for the Example!
