Descarga de datos tipo file e image en survey123
457
08-17-2020 06:12 PM
JuanjoHuiza
Hola a todos, quisiera saber cómo se descargan y se visualizan los datos de una base en Survey123 que se cargaron bajo los campos de file e image. Gracias de antemano.
ZacharySutherby
Hello Juanjo Huiza‌,
Images and files uploaded in the survey will be stored as attachments on the service associated with the survey.
Are you asking about editing existing photos and files in the inbox?
Thank you,
Zach
Thank you,
Zach
JuanjoHuiza
Hello Zach,
I made a survey that contains 2 fields (type file and image) where i have
the problem, i don´t know how to match the information of every row of the
xls file with the images and files uploaded.
Thank you for helping me.
ZacharySutherby
Thank you for reaching out! If you are using ArcGIS Online or Hosted Feature Services in ArcGIS Enterprise 10.8.1 the connection between your attachments and the XLS question is made through attachment keywords. The question's name is what will be used as the attachment keyword and that is how Survey123 knows what attachment is associated with what question.
If you are asking about what attachment is associated with what feature, the attachments are stored in a related table that uses a GlobalID to GUID relationship. Each attachment will have the parent GlobalID associated with it in the related table so each attachment will know what survey submission (feature) it is related to based on the Global ID in the parent table.
Thank you,
Zach
Thank you,
Zach
