Defined values ​​of repetition
375
01-08-2019 03:31 AM
deleted-user-Qx7R82cjFYrM
Where can I find an example of a form of a double entry table, that is, I must separate a total of 30 questions in Male / Female, the same for both sexes and the same districts A B and C. It can be done with repeat as I have reviewed, but I see that the user places the number of repetitions, in this case it is a unique value (only 02)#
NicolasRoger
Look for the column "repeat_count" in your .xlsx file. Set it to 2 at the "begin repeat" line.
Also, you might want to know if you are in the Male of Female section. So you might want to read this post to understand how to read the repeat position : https://community.esri.com/thread/193049-survey123-functionality-calculate-position-in-repeat-group  then you can do (pseudo code): If position = 1 -> text = Male else -> text = Female.
Thank´s Nicolas
