Dashboard from hosted layer not updating in real time
1125
09-30-2023 12:14 AM
DrJumaKhudonazarov
I have large data and created hosted layer  and it allow me to create dashboard. The problem I face my dashboard is not updating automatically though I activate refresh interval. Any advice?
ScottBrown1
Go to the feature layer you’re using for the dashboard data in ArcGIS.com. Click on Visualization at the top, then the “…” on the left. Change the “Refresh interval” from 0 to whatever minutes you want. I believe it can be as fast as 0.1 which is 6 seconds, and save the layer. This should refresh your data at the rate you save and be reflected in your dashboard.
DrJumaKhudonazarov
Thanks, I can not find the visualisation section you are referring..
