Dashboard design joining several survey123 databases
332
04-04-2022 11:34 AM
MiguelMontero
New Contributor II
Dear,
I would like to know how I can design a dashboard with statistics and graphs combining several databases that are captured separately but have the same structure (name of the fields)
DougBrowning
MVP Esteemed Contributor
If you want them all in one I would check out the new Data Expressions.  Few blog posts on it.  If the schemas are the same I would look at a view layer also.  Hope that helps.
jcarlson
In particular, you might look at this example: https://github.com/Esri/arcade-expressions/blob/master/dashboard_data/CombineMultipleLayers(SerialCh...
If the schemas are aligned, joining multiple sources together is quite simple, as data expressions go.
- Josh Carlson
Kendall County GIS
Iron_Mark
New Contributor III
seems to be very interesting.
I would like to do something similar to the other user. I have multiple forms that contain few question with the same name (the other questions are different).
I would like to know more about that javascript git that you linked but I don't know how to model it on my dashboard. Can you suggest us how to integrate it with a simple dashboard with 2 different layers that let us query the same questions from the different layers?
Thank you
MiguelMontero
New Contributor II
Hi, thanks for your response.
I have another problem with the database.
I try to use FeatureSetByPortalItem but my ID has changed and my graph is not updated, it gives a "data source error". If I enter the new portal ID it works, but I need to use an expression that doesn't involve constantly changing the ID.
