Customised thank you screen appearing in the wrong place
5717
20
04-17-2021 10:59 AM
HelenCooper
Hello there,
I've been using Survey 123 Connect for a relatively short while, and wanted to customise the thank you screen.
I've used the 'generated_note_prompt_submitted' note (see screen shot below), but the thank you text appears at the foot of the actual survey screen, rather than once the survey has been submitted.
Any suggestions on what I'm doing wrong?
My survey is here: https://survey123.arcgis.com/share/cafd524cee6a48e0be6a348b43df46c9
Many thanks,
Helen
KinleyWinchester
I was finally able to get this to work by adding the row below to Survey123 connect and choosing "Always use latest version" in the settings.
typenamelabel
notegenerated_note_prompt_submittedCustom Text: ${desired_field_content}
Any design changes for "Thank You Screen" will be overwritten so include everything you want in the Label column.  I have several lines of text and hyperlinks.
