Customise Survey123 form
539
7
05-15-2023 12:44 PM
CatP
Is there a means of customising the Survey123 form so it looks a bit more like the options available in QuickCapture? Specifically, rather than use the standard layout for Single Select Choices I could add images for choices so they look more like buttons.
I can't use QuickCapture because we don't have Hub Premium and need to share publically.
DougBrowning
Do you mean like this?  You can click on each and make them bigger.
You do this using the media::image column in the choices tab.  This is about as good as it gets I think.
DougBrowning
CatP
Yes, that could do the job but I can't see any media or image settings. All options under Add->Choice->(Single Select; Multiple Select etc.) are text only with no option to add media.
DougBrowning
I do this all in Connect.  Sorry not sure in the web builder.
CatP
If it works in Connect then i'll try that. Just found this post about image-map https://community.esri.com/t5/arcgis-survey123-blog/using-the-image-map-appearance-in-survey123/ba-p...
MajidAlabrawi1
hi @DougBrowning  ,
how i can implement this
thanks,
DougBrowning
Use the media::image column in the choices tab.  Add the name.jpg you want then add the actual images to the media folder of the form.  Make sure the case matches exactly.  Be careful on size.
CatP
Thanks to @DougBrowning the solution worked well. I had to play around with the size of the images (outside of Survey123 Connect) to get them to display as I wanted but it now looks very close to what I need.
