Custom URL opening survey based off field in Collector
213
09-20-2018 01:45 PM
CarlHolt1
Currently operating several surveys that work off Custom URLs, but now I want to take New Collector(Collector Aurora)/Survey123 integration a step further. Is it possible to open create an IF/THEN statement for opening a a survey based off a value in a field of a recently dropped point?
Work Flow:
  1. Open New Collector. Drop point at asset, take picture, and select the Structure_Type.
  2. Submit the point.
  3. Click on newly dropped point, and using a custom URL open a survey to inspection that asset based off the Structure_Type selected.
Custom URL: arcgis-survey123://?itemID=679ad6c080c5402a90276d62144371bc&field:structure_type={Structure_Type}
Want to open surveys, with questions unique to each structure type:
struct_typeDWCBDouble Wing Catch Basin
struct_typeSWCBSingle Wing Catch Basin
struct_typeJBJunction Box
struct_typeHCBHooded Catch Basin
struct_typeCICurb Inlet
struct_typeHWHeadwall
struct_typeDIDrop Inlet
struct_typeRLIRaised Lid Inlet
struct_typeEOPEnd of Pipe
struct_typeFESFlared End Section
struct_typeSESSafety End Section
struct_typeFLUFlume
Reply
MarkBockenhauer
Carl,
Yes, I think that should work.  In your Collector feature service set up a domain to have the Applink as a default value for your new feature.   Set up your Survey with conditional response based on the attribute you pass in.
Mark
Reply
MarkBockenhauer
Carl,
Mark
Reply
CarlHolt1
Reply
MarkBockenhauer
Yes, the Custom URL you had in your original question.
