Custom URL for Survey123 App - Forcing update of form
646
02-10-2019 02:25 PM
DudleyHartel
I have the custom URL method to start Survey123 (field) App (currently testing on Windows desktop) and that works fine for both anonymous use of AGOL sign in.
However, if I use this once, and then update the form (Id remains the same) the App pen with the older version.
If I delete the older version form Survey123 App and then invoke the custom URL, it will load the updated form.
I have created a view of the hosted feature layer for use in the form - its settings include Share - Everyone (so anonymous users can participate), and the form is Shared - Everyone
Is there a way to force (when opening the App from a custom URL implementation - I have it on a Windows shortcut) to make it load a new copy and overwrite the form used the previous time?
A second question is whether there is a pulldata() function property to indicate whether the form was access thru a browsers (vs the App)?
JamesTedrick
Esri Esteemed Contributor
Hi Dudley,
Currently, there isn't a way to auto-notify or update a new version of a survey.  If you add a question of type uri:deviceid (click yes when prompted the question isn't in the list), you can determine if the form has been submitted by the field app and if so, which OS.
DudleyHartel
thank you
Dudley R. Hartel
Consulting Urban Forester
Certified Arborist SO-0124A
747 Maxine Dr
Baton Rouge, LA 70808-5931
Twitter: @treeobs
(706) 988-3916 (cell)
