Custom report template map not zooming to geopoint feature
5887
11
08-10-2022 10:44 AM
RyanElvrum1
It appears with the most recent update to Survey123 that the ability to center a map to a point feature when producing a custom report from a survey has been broken.
I have a geopoint that is captured when a survey is submitted with a field name of 'location'. Using a custom report template, I was previously able to center a map in the report on a single point feature. I have shared the expression below. Any clue as to why this function no longer works? Am I missing something? This worked fine in early July and stopped working near the end, so that is why I believe the most recent Survey123 update has something to do with it.
Expression:
${location | mapSettings:"":2400 | size:700:500}
ZhifangWang
Hi @RyanElvrum1 @Debbie_Briedwell ,
We have included a fix for it on the Survey123 Beta website https://survey123beta.arcgis.com. Can you please have a try and let us know if it works for your workflow?
If everything goes well, the fix will be included in the coming September Update planned on 9/20.
ZhifangWang
The fix to the following BUG has been updated to https://survey123.arcgis.com. Thanks again for all your feedback.
  • BUG-000151785 : Map in Feature Report does not zoom to feature when the basemap has a different spatial reference
