Custom Report Template Error: No tag "w:tr" was found at the right.
2099
10-21-2019 01:36 PM
HelenEnander
I am receiving a "No tag "w:tr" was found at the right" error when I attempt to use a custom template. My survey has a repeat. I've tried including the repeat question within the table, and ensured the parameter '#'and '/' are at the beginning and end.
I've also tried combining all tables within the repeat section, two versions attached below... one with separate tables, another with one large table (not preferred) and both receive the same error. Stumped.
Any help appreciated! Thanks!
Courtney
JamesTedrick
Esri Esteemed Contributor
Hi Courtney,
I would definitely not expect the second template to work as it starts a repeat mid-table and ends it outside of the table.  Just to check, is the repeat section large (all the records that are inside the SiteVisit section)?  Have you tried starting with just 1 table within the SiteVisit repeat?
HelenEnander
Thanks James,
It was simply adding the end of the repeat section into the table to fix the issue. The repeat section is quite large, making the template huge, but now it should be a breeze!  Thanks again.
