Create a Database on ArcGis Pro readable and dynamically updated by Suver123
45
04-12-2019 04:47 AM
I need to create a database in arcGis pro, able to be read by survey123 connect to create forms and whose entries are stored in the same data bank, instead of arcGis online.
And at the same time, those survey entries have to be able to be read by Dashboard and Web app Builder.
Any help will be valued.
Thanks in advance!
Reply
Esri Frequent Contributor
Hi Maria,
Survey123 Connect can only create a survey based on a feature service, either hosted in AGO or Enterprise (Portal/Server). You can not create a survey based on local database connection or file geodatabase created in Pro. Please see more information here: https://doc.arcgis.com/en/survey123/reference/survey123withenterprise.htm. The same applies for Dashboards and Web App Builder, you will need a feature service.
Phil.
