Counting Syllables in Survey123
526
07-30-2022 08:24 AM
KyleHicks
Hello Community! I have an idea for a Survey123 app that lets users write a Haiku and assign it to a location. In a Haiku, the first line has 5 syllables, the second 7, and the last another 5 syllables.
Instead of just having an open text field for the Haiku, is there a way to use Python, or some other method, to count the syllables input into Survey123? I’m imagining a field for each of the three haiku lines, and the first field only accepts entries with exactly 5 syllables etc. I’m not attached to that idea but it’s the gist. Let the brainstorm begin!
ZacharySutherby
Hello @KyleHicks
Python would be good for post processing the data it wouldn't be possible to have a Python script run while the user is filling out the form.
If you would like real time validation in the form I would suggest using a custom JavaScript function to parse the text. Here are a few resources that can help getting started with counting the number of syllables in text using Javascript:
https://stackoverflow.com/questions/5686483/how-to-compute-number-of-syllables-in-a-word-in-javascri...
https://www.codegrepper.com/code-examples/javascript/javascript+count+syllables
Thank you,
Zach
