Copy Survey123 attributes to Collector (Feature Layer)
234
06-06-2018 02:51 PM
JohnBickmore
How do I populate an attribute from survey123 back to the feature layer schema where the survey was launched from. I have tree inspections (700ish) which are monitored every year and some have resulting treatments carried out (pruning or removal). I want to be able to see the latest status of each tree in the collector app so i know i have the right tree. I need the date of last inspection and resulting inspection status to populate in the original schema? Each tree may have many assessments however only the latest assessment is required to be displayed, which may be different from the original status in the feature layer used in collector.
JohnBickmore
Im thinking I should just update the feature layer in collector with the latest info, then launch survey123 with a url in the collector schema and copy accross all the attributes and possibly add a bit more detail. That way latest info is in the main feature layer and each assessment is stored via the survey123 feature layer??
