Copy sent data to new survey or edit existing survey tools not working
8303
10
01-25-2018 03:34 PM
AdamDaily
From the Sent box
Copy the sent data to a new survey: I want to replicate surveys but when I create a copy from my completed survey many of the questions do not carry over the attributes. My new copy has blank fields that should be attributed.
Edit and resend survey: I need to go back later and make changes to previously submitted surveys. Same problem as above where many fields that were previously attributed are now blank again. Where did my data go?
I checked the database the survey writes to and it looks like the data is there for submitted surveys, but to field crews filling out surveys, it looks like the data is lost and they now have to go back and redo all of those fields. What might be causing these issues?
AdamDaily
If the missing survey data was captured in the sqlite db, the entire survey should appear in 1 very long text field. Try exporting that table to excel and delimit the data. You can then match your fields up and append the delimited data back to a geodb or AGOL.
