I am fairly new to Survey123 but I have a client that wants to see their geopoint location listed in BC Albers coordinate not UTM, is this possible? Currently I have this to show the UTM coordinate
pulldata("@geopoint",${location},"UTM.easting")
pulldata("@geopoint",${location},"UTM.northing")
Any help greatly appreciated..
Cheers
Tina
Hi @TinaKwitkoski,
We do not currently support BC Albers via the pulldata function. Please refer to the Extract Geopoint Values and Coordinate format sub-section in the help documentation for supported formats. Currently we support additional formats MGRS, USNG, UTM, DMS.
However, if you are familar with JavaScript, you could use a JS function to convert the lat/long value returned from pulldata geopoint into your required format and then display that value in the form to the user.
Please refer to https://doc.arcgis.com/en/survey123/desktop/create-surveys/pulldatajavascript.htm and https://community.esri.com/t5/arcgis-survey123-blog/extending-survey123-smart-forms-with-custom-js-f... for more information on how JS functions work in Survey123.
Regards,
Phil.
