Convert http to https in Survey123
372
06-10-2019 08:03 AM
KevinKozak
Hello,
I have been searching GeoNet for documentation on converting our current web address from http to https. I created my form using http but not sure what the impact will be when my agency makes the change.
Thank you,
Kevin
JamesTedrick
Esri Esteemed Contributor
Hi Kevin,
There shouldn't be much, if any, impact in switching from to https - you can just modify the url after the form has loaded to see.  There might be an issue if your form uses images that have been linked by a URL; if they have an http link, they may not show (this is called 'mixed' (http/https) content).  Updating those links to https would address the issue.
TroyGerhardt1
New Contributor III
Kevin and James,
We are making the same switch.
Just wondering if that prediction of not much if any impact held true.
Also, we have downloaded forms that are used in the field app. I can not find anywhere in survey's downloaded folder that references the URL of the survey's hosted feature service. In one of the *.info files I can see reference to the orgID, Owner, and a folderID, and wondering if that ties the downloaded survey back to the feature service? How ever it works, I am wondering whether to expect folks to need to redownload surveys for the mobile field app after we switch to https.
Thanks for any help
Troy .
