Convert ArcGIs Survey123 connect back to regular Survey123
124
07-23-2024 07:44 AM
JoseSanchez
Good morning,
Is there a wat ti conver an ASurvey123 Connect to a regular Survey123?
I just downloaded a regular  Survey123 in Connect and published it and replaced with Connect.
Thanks
abureaux
MVP Frequent Contributor
Sorry. That's a rather confusing statement and I'm not entirely sure what you mean.
Survey123 Connect (aka, Connect) is the development app. You create surveys in Connect, and then publish them for use in the regular Survey123 Field App (aka, Field App). You cannot collect/submit data with Connect.
The Field App is a data collection app. It downloads surveys published by Connect (or the web builder) and allows for data to be collected/submitted.
You cannot "convert" Connect into the Field App, or vise versa. And you cannot "convert" something from Connect into the Field App. You can however publish something from Connect, download it with the Field app, and they collect/submit data from the Field App.
