Hi all,
I've been using integromat with AGOL with no problem.
Now Im trying to connect with a ArcGIS enterprise instance, but with no success. Ive been following this guide: https://community.esri.com/t5/arcgis-survey123-blog/survey123-tricks-of-the-trade-integromat/ba-p/89...
I make the connection successfully and integromat finds all the surveys but when I press "save" I get the following error:
Any ideas where the error might be? Any help is appreciated!
Hello @refandreoliveira,
Is your ArcGIS Enterprise organization accessible over the internet? Meaning if you were to send me the URL for your Portal I wouldn't need a VPN or anything to access it. Your ArcGIS Enterprise organization will need to be accessible over the internet so that Integromat can communicate with your org.
Hello @ZacharySutherby ,
Yes, I can access enterprise in any device without a VPN.
Some time ago I tried to connect integromat to enterprise survey and was successful. But at the time I was just doing some testing. Now im trying again with no success. This to say that I think it should be possible since there were no modification in our enterprise configuration.
