Configuring Report Layout including Photos
404
06-11-2025 03:06 PM
SW-DanaRobinsonGISS
I am trying to a survey 123 report format so that it is plug and play with folks who do not normally sit in front of a computer.  I am struggling to format the word doc template so that the photos (up to two) along with a geopoint "map" print fully on a page. I understand I have attached two screenshots.  The first is the report Template, and the second is the resulting Report that gets populated.  I have also attached the template and the report.  Is there a way to automate this as it comes out of the survey123 report generator before it is "printed" into a word report?
DeonLengton
Hi
I wonder if your photo is not getting squashed vertically because you are using bullets in your document.
I would try to remove those bullets and see if that fixes the issue.
