Conditional Calculation on Conditionally Relevant Field
621
06-08-2020 12:27 PM
JaredRyan1
New Contributor III
I'm wondering if I can use an "if" statement in my survey to create a conditional calculation for a Total Cost field (integer) who's calculation is dependent on {epm} = Yes versus when {epm} = No.
The condition would be something like:
            if(${epm}, 'yes') then total_cost = ${epm_cost}+ ${repair_cost}
            if(${epm}, 'no') then total_cost = ${repair_cost}
The kicker is that {epm} is only relevent when cat_a, cat_c, or cat_d (and so forth) are selected.
When Cat_B is selected, {epm} cannot be relevant
I've set the default of {epm_cost}, {repair_cost}, and {total_cost} to 0 so that the calculate is run regardless of an actual cost being entered. However, when {epm} is 'no',  {epm} is not relevant and therefore not included into the {total_cost} calculation creating a Null {total_cost}.
I've attached a copy of the specific lines from my survey as well.
Thoughts???
DougBrowning
MVP Esteemed Contributor
I am not sure why your relevant  on line 3 is not the opposite like != '' should work.  That Or sting-length() > 0 will tell you when something is still empty.  Having all those or statements with the value is slower.
For epm just add a second hidden field.  You can do the same string-length trick above or just use epm ='yes' again (no need to use selected just = is fine).
So if(${epm}='yes',${epm_cost},0)    then use this hidden field in your calc.
Hope that helps.
JaredRyan1
New Contributor III
Thank you Doug! This works for what I'm needing, with the one exception that my total_cost is concatenating the new hidden field instead of adding it to the total as a sum. I believe this is a separate issue as I have verified my bind::esri:fieldType is set to esriFieldTypeInteger. I have also created a new identical survey to first publish with the new hidden field as an integer and then republish as hidden and esriFieldTypeInteger and it's still concatenating. My total_cost calc is coalesce(${epm_cost},0)+coalesce(${repair_cost},0)+coalesce(${epm_cost_b},0) where epm_cost_b is the new hidden field.
DougBrowning
You need to set bind::type one to int instead.  Or use number().
JaredRyan1
New Contributor III
Ah thank you! I hadn't even realized I was using an old survey form that did not have the bind::type column.. All good now.
