Compare value of 2 fields in feature report template
172
3 weeks ago
RobBlash
I want to compare to fields in a report template but I am not having luck. I want a conditional element like this: ${if field1 != field2} some text ${/}
I've tried a few ways but I can't get the syntax right. None of the below works
${if field1 != ${field2}}
${if field1 != '"+field2+"'}
Has anyone successfully done this?
Neal_t_k
I was able to get below to work using test data.  Is it giving you an error message that you can share?  Is one of the fields in a repeat and the other outside?
Text here
Neal_t_k
@RobBlash this also appears to work in tests, however if one of your fields is in a repeat, not sure it would work either:
${#mainLayer | where: "field1 <>'"+ field2+"'"}
text here
Edit: If one field is in a repeat
field1: main layer
field2: in repeat
${#repeatlayer |where: " field2 <>'"+field1+"'"}
text here
RobBlash
Fields are not in a repeat. The site would accept the syntax for ${if field1 != field2} (no errors) but it didn’t actually produce the expected result when exporting a sample report. I think the other 2 options threw a syntax error when trying to upload the template.
Thanks for the reply, in the end I updated the survey to eliminate the duplicate values and put a static “NA” in field 2 that I can easily query for in the report template.
