Combining two feature layers for Survey 123
2427
10
10-18-2017 12:08 PM
SMW_GIS
I was wondering if anyone has had any experience in combining two feature layers for Survey 123. For our client, we did condition assessments on their assets using Survey 123 with the form hosted on our organizational account. They have now taken the form and are hosting it on their organizational account for all future condition assessments (a few fields have been added to their form as well as choices in the choice lists). They want to combine the data we collected on our feature layer to theirs, so that all the data is stored in one place. Does anyone know if this is possible?
TL2
Could you export your data to a file geodatabase, then use ArcGIS Pro to append to the destination table.  That's what I would try.
ShanaGail1
I'm trying the Append in AGOL but haven't tried ArcGIS Pro yet.  So far it's hanging up on "Analyzing data..."  and never completes.  Did you try TL suggestion with success?
ShanaGail1
I discovered (with the help of an Esri Analyst) that the Append function to a hosted feature layer in AGOL cannot handle related tables.  My survey had repeats, so I was out of luck going that route.  We tried using the Append geoprocessing tool in ArcGIS Pro, and was able to update the parent table successfully.  However, the Global ID was not preserved and the related tables were not updated.
The Esri Analyst logged these enhancement requests:
ENH-000113718 : Allow Workflow or ability for Survey123 to load, or append all records from a previous survey that included Repeats, i.e relationships in the Hosted Feature Layer.
ENH-000113717 : Add ability or workflow that would allow Append operations to preserve Global ID for hosted feature layers with relationships .
The Analyst suggested these workarounds:
-For Survey data without repeats/relates: Append In Pro to Hosted Feature Layer
-For Survey data with repeats/relates: Append in Pro using Preserve Global ID to Enterprise Geodatabase.
I hope this helps somebody else .
Shana
ShanaGail1
Kristy Nicoll‌ Hi Kristy, I meant to update this thread...  I did on a different conversation.  At the UC I asked about this issue in a workshop and the person leading it (Paul Barker?) was able to do the append using a related table.  So perhaps my issue had a root cause of something different.  Just didn't want to send you on a wild goose chase!
by Anonymous User
Not applicable
Thanks for the update Shana! I've been unable to append with related tables at all. Seemed like your solution would work for me but i've been getting a 999999 error when I use preserve global IDs. Going to open a case this morning in case there is something silly i'm missing.
ShanaGail1
Thanks for pursuing it further.  I wouldn't be terribly surprised if we encountered it again, so if you post the outcome here, that would be awesome!
GretchenFolse
We are running into a similar problem when trying to reload previously collected survey data to a republished Survey123 hosted Feature Layer.  We're using Survey123 as our collector app for HazMat incidents (because the built-in Reports in Survey123 are pretty snazzy), and we have repeats built in for responding agencies, vehicles and chemicals involved, and for including photos of the incidents and the clean-up ops.
Using Append through ArcGIS Pro seems to work great for reloading all of our data to the republished survey EXCEPT the photo attachments.  It creates the same number of placeholders for the photos in the appended data, but the actual photo attachments are left behind.
For example:
If report number 18-0807-1000 originally had 7 photo attachments in the repeat table (accessible and visible from the hosted Feature Layer's "Show Related Records" in AGOL Map Viewer, as seen in screenshot below)...
Related Records table of photo attachments in original Feature Layer
...the new Feature Layer with the appended data (exported from the original survey as a FGDB then appended in ArcGIS Pro) would have the same number of records in the related photo repeat table, but no "Photos and Files" to view (as illustrated in screenshot below).
new Feature Layer with data appended from exported FGDB of original survey
The way it was explained to me:
"In short, as of now, there is no easy way to append features with repeats to a new feature class/service, regardless of a schema change. This is because repeats consist of a relationship with a related table based on a global ID, and the Append tool regenerates the global ID for each record when it is appended to the target layer. Essentially, when the new global ID is generated, the relationship to the repeat table is broken."
Makes sense, I suppose.
As of now, my understanding is that ENH-000113718 (Allow Workflow or ability for Survey123 to load, or append all records from a previous survey that included Repeats, i.e relationships in the Hosted Feature Layer) is currently marked as Not in Product Plan.
This is the suggested workaround: https://community.esri.com/groups/survey123/blog/2018/07/17/how-to-turn-supportsapplyeditswithgloabl...
The second enhancement, ENH-000113717 (Add ability or workflow that would allow Append operations to preserve Global ID for hosted feature layers with relationships), is In Product Plan.
If anyone has luck with this workaround, please share your scenario and let us know how it worked out.  :-]
GaryBowles1
We ran into the issue of attachments not loading into new SDE datasets that we created to deal with 3D data. We developed a work-around for this that was fairly complex but it worked. I have attached a powerpoint from a presentation i gave about this. If you want more info, or need some clarification email me and we can see if this will work for you. There may need to be some modifications made for the repeat tables but I think it should work.
good luck,
--gary
ShanaGail1
Hi Gretchen,
Thanks you for the update.  We ended up reattaching the photos to the HFL by writing a Python script, with some pre-work using FME.  Would that be an option for your organization?
Shana
