I am a relatively new user of Survey123, though I successfully deployed a survey using repeats earlier this year. This survey was for information about each group of people encountered while hiking a trail, such as the number of humans/dogs and whether they were camping. Each encounter was recorded in a repeat, with the appearance set to "minimal" so that the label and a plus sign appeared initially. The surveyor would create a new repeat record each time they encountered a new group, which would happen intermittently during the hike.
I found that one of the most frequent causes of user confusion and error was what to do after entering all the data for a record in a repeat. There is an intuitive urge to do the equivalent of pressing "Enter" to complete the entry and move on to the next thing. If the next task is to immediately start another record for a new encounter in the same repeat, then it is intuitive enough to press the plus sign at the bottom of the repeat block and start the next record. But if they do not immediately encounter another group, it is disconcerting for them to leave the first record "open".
If they press the plus sign to start a new record, but don't have another encounter before the end of the hike, that blank record (which has required fields) prevents them from submitting the survey. Some people were able to figure out to go back and use the trash can to delete the blank record. But others were flummoxed and the best they could do was save the survey in Drafts and contact me about what to do.
I encourage people to use the triangle button at the top of the repeat block to collapse the repeat block after each encounter. But then when they have the next encounter, the plus sign is no longer visible and they have to reopen the block using the triangle and scroll down to the end of the previous record to find the plus sign to start a new record. But this was also less than intuitive and I got negative feedback on the whole process.
I'm in the process of deploying a new version of this which will have multiple repeat blocks, in addition to Encounters, such as campsite conditions, trail issues etc. Users will need to move among different repeat blocks depending on what type of condition they run across and need to create a record for. I anticipate this "how do I finish the record and close the block?" confusion to be even more of an issue.
Ideally there would be a way to confirm the completion of each record in a repeat, which could be set to return the repeat block to its initial appearance state: closed, with the label and a plus sign. Pressing the plus sign would open the block and start a new record, just as with the first record. But I have searched the internet, the S123 documentation and this forum without finding a way to do this or otherwise control the behavior after a repeat record is completed.
Is there a setting, tool, calculation, incantation or workaround that could be used to give the user a more positive way of completing the record and, ideally, closing the block and returning to the initial appearance, or at least approximate that? Any suggestions you might have would be very welcome.
Dave
This isn't really advice regarding repeats in Survey123, but have you looked into using QuickCapture as an alternative? Overall the functionality is more basic than S123 but I find it works great when I'm looking to capture a series of isolated incidents over a span of time (like when someone's walking over a distance) and the details of each incident are relatively simple (a couple questions and a photo, for example). Provided your form doesn't have a lot of additional questions outside repeats, it sounds like it could be a good fit.
You can configure a QuickCapture project to have multiple buttons, each button represents a feature type - e.g. one button could be "Encounter", one could be "Trail Damage", one could be "Campsite Litter", and so on. Pressing the button opens input for text/numeric input (if required) and/or a photo (if required). There's no need to navigate between repeats, it gives you locations of each incident as separate point features, and "closing" is intuitive as you submit each incident in isolation.
Thank you! I am not familiar with Quick Capture but will look into it. But we are pretty committed to Survey123 and I suspect we will need its full capabilities for the current project as well as planned further ones. Other than this repeat annoyance S123 is working perfectly for our needs and users are happy with it. In order to keep taking advantage of all of its capabilities I really want make it work, preferably with at least some mitigation of this issue.
Dave
Hi @DavidSJohnston,
Currently there is no way to control the apearance of a repeat (expanded/collapsed) via calculations or settings controlled via the data entry in the survey form. This can only be done on form load using the minimal appearance, and by user interaction of the collapse button.
One option could be to add a note at top of repeat telling the user to delete the repeat record if no more groups are encountered. Additionally you could add an initial question at the start of the repeat, which asks the user if they want want to enter a new record or continue, and has a yes/no, with the default as no, and based on this you can set all the following questions to be not-required and hidden, until they click yes. This would allow submitting the survey as there would be no required questions in that open record, however will create a blank record in the repeat table when submitted. This would require clean up after submission.
Hope this helps.
Regards,
Phil.
Hi Phillip, yes that helps. At least I know to not bother trying to pursue a solution that does want I want!
I'll explore the workarounds you suggested, which might have some value. I appreciate your envisioning things that would at least reduce the incidence of confusion or bad data.
Dave
Again not an optimal solution you, but have you considered a "pages" style and have a separate page for each of your repeats.
Sounds like pages may have promise. I assume that each of what I am currently structuring as repeats could be incorporated into a separate page, and that the repeat can then be placed in that page? And that groups within that repeat will behave the same (that is, not be treated as pages) so long as the appearance is not field-list? And that the pages need not be sequential, but can be selected randomly from a menu or list? If the above are true, I think that may work. I will certainly give it a try.
For questions that relate generally to the survey (that are not repeats) such as the date and name of the surveyor, can those be placed outside of a page, or should they be placed on "Page 1".
Thanks so much for this suggestion. I hope it pans out.
Dave
@DavidSJohnston Surveyor name and date can be "outside" of a page, i.e. hidden.
Are surveyors using the field app or the web. In the field app, if you click on the page number at the bottom, the TOC opens and users are able to select a page. As far as I know, that is not possible in the web app, and would go in order. Probably not the exactly what you want.
Going off a combination of what @Philip-Wilson said, using the "body::esri:visible" column and pages style, see the attached example. If pages are not to your liking just get rid of the widths and field-lists in the appearance column. I think it might get close to what you are after.
Thank you Neil. Your example gave me enough to get started on converting my repeat-driven form to pages, and it looks like that will improve the interface considerably. Most notably, if allows true random access to the pages for each topic without having to scroll through other repeat blocks which may be open. All of these survey would be done on the field app, so there is no issue using the page number bar to call up the list of pages. That works really well.
The only thing that is still counterintuitive is that it appears that the check mark to submit the survey is only visible when one is on the last page of the survey. To submit the survey the user has to purposely go to whatever the last page happens to be to find the check mark. I'll probably need to create a discrete "End" page so that will show up on the list and clue the user to go there in order to finish. I can probably use that show some final or "thank you" messages, so that isn't necessarily a bad thing. But still, it would be nice if there were a way to submit the survey from within any of the pages.
Again, that you and all the others who offered helpful suggestions. Thanks to you I'm one step further down the road of using Survey123 to meet our group's needs.
Dave
Neil, an update on the option of using pages. I have transitioned my project to a pages-based survey, and added more content. I'm having some users check it out and they like it, enthusiastically. there is still the problem of not "completing" a repeat after the data is entered, but pages makes t easier for them to just move to another page rather than having to do a lot of scrolling in order to get to another topic. thanks so much for this suggestion.
Dave
