Choice filter not working in Survey123 Connect v3.12.230
2519
03-03-2021 07:22 PM
by Anonymous User
Not applicable
Re-posted from this comment on What's new in ArcGIS Survey123 9 February 2021) blog post
I'm seeing some unexpected behaviour using Survey123 Connect v3.12.230 and Survey123 on Android v3.12.274 with select_one questions with choice filters (bold red in below example).
When a choice filter is present the select_one selection lists won't display.
This isn't an issue in Connect v3.11.123 or Android v3.11.164.
type
name
label
required
required_message
appearance
default
readonly
relevant
calculation
choice_filter
bind::esri:fieldType
bind::esri:fieldLength
text
ASSNBRI
Asset #.
yes
esriFieldTypeString
40
hidden
raise
Value can be used in field
y
null
select_one classification1
CLASSIFICATION1
Utility:
yes
minimal
if(string-length(${ASSNBRI}) = '0', '', 'yes')
${raise} = RAISE
esriFieldTypeString
40
select_one classification2
CLASSIFICATION2
Asset Class:
yes
minimal
${CLASSIFICATION1} = CLASSIFICATION1 and ${raise} = RAISE
esriFieldTypeString
40
select_one classification3
CLASSIFICATION3
Asset Type:
yes
minimal
${CLASSIFICATION1} = CLASSIFICATION1 and ${CLASSIFICATION2} = CLASSIFICATION2 and ${raise} = RAISE
esriFieldTypeString
40
I tried changing the format of these expressions to the below, but this has no effect.
                selected(${raise}, RAISE)
                selected(${CLASSIFICATION1}, CLASSIFICATION1) and selected(${raise}, RAISE)
                selected(${CLASSIFICATION1}, CLASSIFICATION1) and selected(${CLASSIFICATION2}, CLASSIFICATION2) and selected(${raise}, RAISE)
Choices:
list_name
name
label
CLASSIFICATION1
CLASSIFICATION2
CLASSIFICATION3
RAISE
classification1
Stormwater
Stormwater
y
classification1
Wastewater
Wastewater
y
classification1
Water Supply
Water Supply
y
classification2
Bore
Bore
Stormwater
y
classification2
Chamber
Chamber
Stormwater
y
classification2
Channel
Channel
Stormwater
y
classification2
Control System
Control System
Stormwater
y
classification2
Electrical
Electrical
Stormwater
y
classification2
Filter
Filter
Stormwater
y
by Anonymous User
Not applicable
@JohnPlunkett @ Eagle Technology spotted the problem.
BUG-000137897 Cascading select does not work in ArcGIS Survey123 3.12 if a field used as the choice filter has a name which is listed as a reserved keyword for SQLite.
My survey was using the keyword RAISE, changing this to ACTIVE resolved the problem.
DougBrowning
MVP Esteemed Contributor
I have seen weird things happen when the list name and field name are the same.  Change to like ClassificationList or something.  For Raise I would put "y" in the calculation vs default - defaults do not always work.
My choice filters I all wrote the opposite, not sure that matters but I have RAISE = ${raise}
These are just guesses though since you said this worked before.  Hope it helps
Another with the same issue?
https://community.esri.com/t5/arcgis-survey123-questions/select-one-from-csv-field-empty-on-iphone/m...
by Anonymous User
Not applicable
Thanks for these suggestions, unfortunately no change though.
This is a survey that's been in use for over a year now, it's functional with versions 3.5 to 3.11.
by Anonymous User
Not applicable
SolanaFoo2
Thank you for posting!  Racking my brain all night on this.
