Re-posted from this comment on What's new in ArcGIS Survey123 9 February 2021) blog post
I'm seeing some unexpected behaviour using Survey123 Connect v3.12.230 and Survey123 on Android v3.12.274 with select_one questions with choice filters (bold red in below example).
When a choice filter is present the select_one selection lists won't display.
This isn't an issue in Connect v3.11.123 or Android v3.11.164.
type | name | label | required | required_message | appearance | default | readonly | relevant | calculation | choice_filter | bind::esri:fieldType | bind::esri:fieldLength |
text | ASSNBRI | Asset #. | yes | esriFieldTypeString | 40 | |||||||
hidden | raise | Value can be used in field | y | null | ||||||||
select_one classification1 | CLASSIFICATION1 | Utility: | yes | minimal | if(string-length(${ASSNBRI}) = '0', '', 'yes') | ${raise} = RAISE | esriFieldTypeString | 40 | ||||
select_one classification2 | CLASSIFICATION2 | Asset Class: | yes | minimal | if(string-length(${ASSNBRI}) = '0', '', 'yes') | ${CLASSIFICATION1} = CLASSIFICATION1 and ${raise} = RAISE | esriFieldTypeString | 40 | ||||
select_one classification3 | CLASSIFICATION3 | Asset Type: | yes | minimal | if(string-length(${ASSNBRI}) = '0', '', 'yes') | ${CLASSIFICATION1} = CLASSIFICATION1 and ${CLASSIFICATION2} = CLASSIFICATION2 and ${raise} = RAISE | esriFieldTypeString | 40 |
I tried changing the format of these expressions to the below, but this has no effect.
selected(${raise}, RAISE)
selected(${CLASSIFICATION1}, CLASSIFICATION1) and selected(${raise}, RAISE)
selected(${CLASSIFICATION1}, CLASSIFICATION1) and selected(${CLASSIFICATION2}, CLASSIFICATION2) and selected(${raise}, RAISE)
Choices:
list_name | name | label | CLASSIFICATION1 | CLASSIFICATION2 | CLASSIFICATION3 | RAISE |
classification1 | Stormwater | Stormwater | y | |||
classification1 | Wastewater | Wastewater | y | |||
classification1 | Water Supply | Water Supply | y | |||
classification2 | Bore | Bore | Stormwater | y | ||
classification2 | Chamber | Chamber | Stormwater | y | ||
classification2 | Channel | Channel | Stormwater | y | ||
classification2 | Control System | Control System | Stormwater | y | ||
classification2 | Electrical | Electrical | Stormwater | y | ||
classification2 | Filter | Filter | Stormwater | y | ||
@JohnPlunkett @ Eagle Technology spotted the problem.
BUG-000137897 Cascading select does not work in ArcGIS Survey123 3.12 if a field used as the choice filter has a name which is listed as a reserved keyword for SQLite.
My survey was using the keyword RAISE, changing this to ACTIVE resolved the problem.
I have seen weird things happen when the list name and field name are the same. Change to like ClassificationList or something. For Raise I would put "y" in the calculation vs default - defaults do not always work.
My choice filters I all wrote the opposite, not sure that matters but I have RAISE = ${raise}
These are just guesses though since you said this worked before. Hope it helps
Another with the same issue?
Thanks for these suggestions, unfortunately no change though.
This is a survey that's been in use for over a year now, it's functional with versions 3.5 to 3.11.
Thank you for posting! Racking my brain all night on this.
