I created and published a Survey in Connect and then tried to create a Dashboard from the data I collected. I set a facility rating using the select_one answer and then set the appearance as a Likert for ease of use for the mobile user. Unfortunately I was unaware that this would produce a text answer instead of a numeric value and now I have 30+ records stored this way.
1. Is there a way, post publishing, to alter this text string to a numeric value?
2. If not, I can make a copy of the survey in the Connect program, but is there a way to import the data from the original survey into the new/copy so I don't lose data or have to reproduce it?
I have photos included in the survey and I am not sure how to go about making a change like this. I know that once a survey has been published, changes to the survey can be a hassle.
Any detailed help would be very helpful
Hi Doug
You can create a new numeric field for your feature layer then use the Calculate method to populate it with the integer value of your string variable...
is this something to be done in Pro? I saw a thread about doing something like this, but have never done something like this before.
Hi Doug
You can add a field to a Feature Layer in ArcGIS Online.
Go to the Feature Layer - then go to the Data Tab... Then go to Fields...
You can then add a field of integer type and you can do the calculate field in a webmap.
OK, I did this and it worked perfectly. My next question: is there a way to make the new surveys auto calculate into the new field? I added a new survey and the new field is blank for this particular survey. My end goal is to create a dashboard for this survey, but cannot without the numeric values and having to manually perform the calculation from time to time would not be desirable.
Hi Doug
Yes you can now add this new field as a hidden field in your survey and use the calculate functionality to do the formula... Just make sure you set the bind::esri:fieldType to esriFieldTypeInteger to match the type of the question you added...
Ok, I understand why i need to do this, but I am struggling to get this to work. Sorry, I am very green at making surveys and any extra details are helpful.
I have tried to enter the calculation here, but must be imputing it wrong. Not sure what or where to insert the formula as I cannot get it to work
Is this where it put the bind code?
Sorry again, really new to all of this
If you are wanting to keep the question within your survey, then you might want to try the following, but please be very careful with this method. If there are values within the text field that cannot be converted into a number through field calculator, then plan on creating some "select by attribute" and then "calculate field" based on what the values they should be converted to.
This is another way to get the field into your survey and to replace the question at the same time. If for some reason you need to just "archive/retain" the question, then you can just add a new field within Survey123 connect, turn the "Type" from "text" to "hidden", and then add the new question to accept the new answers. However, you would have to calculate the answers from the numeric field into this new field as stated above.
Cheers,
Mike
