Change order of columns in Data tab for the web
2255
06-04-2020 11:31 AM
RichOchs
Is it possible to change the order of the columns in the Data tab in Survey123 for the web? It appears that I can add/remove columns from view, and I can sort rows, but the columns always show up in the order they were created. The issue is when I have added questions to my survey and changed the order of the questions, the columns remain in the same order no matter what. I am sure I'm missing something,and any guidance would be appreciated.
DougBrowning
MVP Esteemed Contributor
Change the order in the popup and the table will honor that change.
Hope that helps.
JC-220
I'm having the same issue. Which popup are you referring to?
ColeFreeman
pls, what popup?
LMedeirosUI
@DougBrowning What popup are you referring to? The popup in Map Viewer?
