Change Group Background Color based on Any data input
969
02-20-2025 10:53 AM
Indy
Just learning Survey123 Connect.
Currently, I have crews moving back and forth between repeaters throughout the day, capturing events as they occur. Because of this, I can't make any field required because then crews can't start another repeater without first completing the previous repeater, which may not be possible until later in the day. So they need to be able to move back and forth between repeaters, but I also want to make sure all the fields I would normally set as required are capture...So I though, perhaps, maybe having the background color change to green in each group of the repeater once they have been 'complete'. I've been playing with different conditional formats and calculations but can't seem to get the group background color to change based on all fields within a group having data in them.
Example would be:
Repeater: Contract Group Name
group: Contract Crew (background turns green once names have been captured, any name from autocomplete select_one_from_file list of about 250 names for crew 1, 2, 3, etc.).
additional 4-5 groups within repeater.
LaurenceTait
