Hi All
I was wondering if its possible to centre a geotrace or geopoint question map based on the coordinates of a point from Collector.
The use case is that we have a Collector Map showing the point location observations of pest plant and animals. The field officer will select a point then have a hyperlink to open Survey123 to either capture a line or polygon treatment area. The officer may not always be at the exact location of the point in question, so using the default GPS location isnt always an option. I have tried just passing the lats and longs of the point (using Arcade) to the geotrace question but it doesnt seem to work.
Cheers
Chris
Any thoughts on this anyone?
