Capture coordinates when I am offline and Create polygon automatically
249
01-23-2019 05:43 AM
RawandDizayee
Dear Team,
We are working in Mine Action program we are starting to use survey123 in the field could you help me with these questions:
- Best way to capture coordinates when I am offline because it takes a bit time to capture it.
- is there any news to create polygon automatically when using repeat for coordinates
i will appreciate it if you help me for any new ideas which are useful for survey123 that should be awarded for.
Thank you
JamesTedrick
Esri Esteemed Contributor
Hi Rawand,
- It is expected that it will take a bit of time to capture a point when offline as the phone must rely on getting location via GPS (which can take some time to get a sufficient number of satellite signals to determine location)
- Currently, the capability to assemble a polygon from points is not available in Survey123.
