Cannot see any of our Surveys in Portal 10.6
409
07-16-2019 11:00 AM
by Anonymous User
Not applicable
Hi all,
I am (and all the organization) still having issues accessing our Survey Forms from our Portal 10.6.
Here is what I get:
Any help is welcome,
Alex
Tags (1)
by Anonymous User
Not applicable
JamesTedrick
Esri Esteemed Contributor
Hi Alex,
What is the specific error you are seeing?  Is it the same as you previously experienced in https://community.esri.com/thread/235150-survey-123-portal-error-code-11-web-site ? Also, have you opened an Esri Support case on this?
by Anonymous User
Not applicable
James,
There no more messages thrown at me like last time. I have opened an ESRI ticket and gave admin level to our Portal to ESRI tech support.
Esri Case #02372432 - Surveys do not appear in the Enterprise Survey123 website
When I click "Create a new survey", it says: you dont have access to this feature. required privileges: publish hosted layers. but I am an administrator.
When I went to the UC San Diego. It worked correctly at the booth that seemed to run on Portal 10.7.1. We currently are on 10.6.1
Alex
by Anonymous User
Not applicable
