Cannot republish survey after simple field additions
904
06-25-2024 06:07 AM
janine_mapss
Hi all,
I am trying to update and republish an existing survey after adding four questions. The data type for all is a string. There are two select one questions and two text questions. When I click publish it just loads and loads but does not ever publish (see screenshot for where it gets stuck). The only way to exit is to close Connect. I have waited a long time, closed and tried again many times and even tried on somebody else's computer with no luck. I also deleted the survey off my device, redownloaded it and made the changes again. This survey has been republished several times before with no issues. There is a lot of existing data which is connected to a dashboard so I cannot start again from scratch with this survey.
I know this is a problem that happens when the survey form is moved to a different folder in ArcGIS Online but I checked the iteminfo ID and it matches. Other suggestions said to update the schema with the additional fields on the hosted feature layer on ArcGIS Online and then try to republish the form from Connect. I do not have the option to add fields this way despite being the administrator. I'm not sure why. Perhaps because there is a join?
Any help would be greatly appreciated. Thanks in advance.
janine_mapss
The problem was that a join had been created with the feature layer that was linked to the survey form in ArcGIS online. This join was created in 2022 and the survey has been republished several times after this, with the most recent changes made a few months ago. I am not sure why this was an issue now. Once I had deleted the join, the survey form republished with no issues.
abureaux
MVP Frequent Contributor
Can you attach your XLSX?
ChristopherCounsell
Does the folder have the same name? Survey-SurveyName?
Did you rename the form item?
ArcGIS Online and then try to republish the form from Connect. I do not have the option to add fields this way despite being the administrator. I'm not sure why. Perhaps because there is a join? This join was created almost two years before the survey was last republished so I don't think this is the issue anyway.
Yes, you can't add fields (new questions) to a layer with a join. Survey123 Connect would not be able to re-publish and add the new questions and related fields. You need to remove the join layer.
janine_mapss
