Can you create a report from a survey create in Survey123 Connect?
293
09-28-2021 06:26 AM
ab802319
I created a survey using Survey123 Connect rather than using the website. I know you can create a report if you used the website. Is there a way to create a printable report if you created it through the app though?
My survey uses a feature service and has a repeater for images that's way I had to use Connect.
Thanks!
DeonLengton
Hi
If you go to https://survey123.arcgis.com/ you will be able to draw a report by going to the Data tab of the survey and clicking on Report:
You can also look at this blog:
https://www.esri.com/arcgis-blog/products/survey123/announcements/introducing-survey123-feature-repo...
and this Survey123 document:
https://doc.arcgis.com/en/survey123/browser/analyze-results/printsurveyresults.htm
DeonLengton
Hi
ab802319
Thank you, I didn't have any data yet in the survey so it wasn't showing at first. Now I see it!
