Can you configure the template or feature report to omit null fields?
6015
9
08-02-2019 07:49 AM
MikalaRandich1
Hello,
I was wondering if you could configure the template in Survey123 or the feature report tool to omit fields from the report that have null or no response?
Thanks for any assistance!
Mikala
Jim-Moore
Hi Mikala
You can use conditional statements in your feature report template to show or hide content. For example, to show a text question only if it has a value, you could use something like:
${if text_question!=""}
Text Question: ${text_question}
Please find details on conditional elements here: Feature report templates—Survey123 for ArcGIS | ArcGIS
Hope this helps,
Jim
Jim-Moore
Hi Mikala
Hope this helps,
Jim
MikalaRandich1
Thanks so much Jim, that worked!
ToryChristensen
Hi Jim,
Is there a way to avoid creating a new line for every question so that if it is blank, there will be no empty row created on the feature report? Thanks
Jim-Moore
Hi Tory, thanks for your query, this is a known issue with conditional elements in a report template. If possible, could you please log this through Esri Support so we can add it to cases raised by other users? This helps us prioritise enhancements and fixes.
Best,
Jim
KarolFallas
Hi Jim,
Is there any news regarding the topic?
"Is there a way to avoid creating a new line for every question so that if it is blank"
Thanks.
Jim-Moore
Hi Karol, no update on this issue at this stage - it is still in our backlog; but as mentioned above, please feel free to report it through Esri Support so we can add your case to the issue.
Best regards,
Jim
KarolFallas
Thanks Jim,
I used:
${/} ${field1=="categoria"}
descripcion field1: ${field2}
descripcion field2 ${field3}
descripcion field2 ${field4}${/}
That worked for my workflow.
Best regards
Karol
JamesDanielsJr
Can someone please show this in the context of a report template? For example, if I have a question in my template that reads:
Location of project area monitored:
${location_of_project_area_monito}
How would I apply the conditional visibility syntax?
Jones_AJ
Agreed, would love to see this in context of a report template to not only hide the value but the text. Has there been any progress on this since?
