Can the publish dialog box have resize option please
111
11-03-2020 11:19 AM
MVP Frequent Contributor
The warning box on a publish dialog is so small I cannot actually read the field names.  Plus there is no way to resize it.
Can you please make it so it can be resized?  It has limited use if I can't read anything on it.
Thanks!
Reply
Hi Doug,
Thanks for reporting this. I had logged an internal issue for this UI enhancement and I would also encourage you to contact Esri Support. Our Support team will assign an official enhancement number for your records. Similar requests from other customers can then be attached to the same enhancement request, which helps us assess demand for the enhancement and prioritize it accordingly.
Hi Doug,
