Can't upload Survey123 records
2023
09-21-2021 09:01 PM
MarcoPoetsch
for one of my surveys my fieldworkers can't submit records anymore.
I investigated and I'm pretty confident that I was able to identified the cause. However, I do not know how to fix it.
In the Suvvey123 settings under CollaborateShare Survey > What can submitters do?
The tick boxes are all empty:
When I enable the first record (Only add new records) and click on save, the page returns that the settings have been saved successfully. However, as soon as I refresh the page, nothing is ticked anymore.
If choose either Add and update records or Add, update and delete records, I get following error message:
{"error":{"name":"ArcGISRequestError","message":"400: Unable to update feature service definition.","originalMessage":"Unable to update feature service definition.","code":400,"response":{"error":{"code":400,"message":"Unable to update feature service definition.","details":["Invalid definition for 'Capabilities'.","Invalid definition for System.String"]}}
alison_gou
Hi @MarcoPoetsch ,
Maybe you can try to directly set on feature server. In order to do this, please follow:
  1. go to your organization --content, find your survey under Folders. The folder name starts with 'Survey -'
  2. once your survey is found, click on folder name  and find feature server of which name ends with  '_fieldworker'.
  3.  go to setting -- What kind of editing is allowed? , click on 'add' 'delete' 'update' accordingly. Once this is set successfully, it should be reflected on Collaborate page of your survey.
Just give it a go and see if this would work.
Besides, I am also curious does this issue only happen to one survey or more than one surveys?
Regards,
Alison
alison_gou
Hi @MarcoPoetsch ,
Regards,
Alison
MarcoPoetsch
of course... I should have thought about that too.
It's working now... So all good. Thanks!
PS: this was the only one which made troubles 🙂
