Can't Sign into Survey123 2.8.2
440
06-28-2019 08:47 AM
WilliamShoop
New Contributor III
Some of our users have experienced this error where he/she clicks the Sign In button and nothing happens. I understand starting in 3.0 the credentials are stored in Windows credentials and if cleared out the user can sign in and add our company's Portal. Is this the same case for 2.8.2? I am not seeing any Survey123 credentials stored in windows credentials. We have uninstalled and reinstalled already.
Any help is appreciated.
Bill
Tags (1)
WilliamShoop
New Contributor III
I should also note that I logged into the device seeing the unresponsive Sign In button with my credentials and was able to install ArcGIS Survey123 2.8.2, Sign in, and add our Portal. But when I logged off the device and the user logs back on and tries it, the Sign In button is still unresponsive. Why would it be different experiences for different users on the same PC?
JamesTedrick
Esri Esteemed Contributor
Hi William,
Can you try with the current release (3.5) and see if you have the same issue?
WilliamShoop
New Contributor III
Good Morning James,
Thanks for reaching out. We have tried the current release 3.5 with the same result. The user is a member of our organization's Portal as a Level 1 Viewer.
Bill
JamesTedrick
Hi William,
Are they logging into the field app?  If so, a Viewer is not able to log into the field app as they cannot submit new records nor revise existing ones.
