Can't generate reports w/ multiple line appearance in report template
1574
5
12-02-2019 07:19 PM
JamesBailey
Can't generate report, I receive the following error - "Error occurred when rendering by the report engine. The tag "nested_repeat_1.field1|appearance:"multiline"". The tag "nested_repeat_2.field2|appearance:"multiline"" should be the only text in this paragraph."
The quoted line is repeated multiple times, from other posts on the forums it seems that multiline appearance is not compatible with report templates.
These seems to be known about for almost two years, is there a fix in place/specific formatting or patch coming soon?
Cheers
Shwu-jingJeng
Hi James,
It looks like the issue is related to the formatting in the template. I tried to move the appearance:"multiline" to a standalone line and it will work.
Could you try this report template I modified to see if that works for you?
Shwu-jingJeng
Hi James,
Do you refer to the issue that the error message repeat two times <The tag "nested_repeat_1.field1|appearance:"multiline"". > on the website?
Or you have issue with appearance:"multiline" with your report?
Would you share your xls form and the report template with us to take a look here?
JamesBailey
The error appears when I try to generate a report with my report template.
I had several text fields which didn't honor the format they were entered into Survey123 once generated into report template so I tried to apply appearance:multiline in the report template to all my multiline questions but received the below error to dozens of fields.
Error occurred when rendering by the report engine. The tag "nestedrepeat.repeatedfield|appearance:"multiline"". The tag "nestedrepeat2.repeatedfield2|appearance:"multiline"" should be the only text in this paragraph.
The error was not applied to all multiline but was not consistent why some errored and why others didn't. I ended up deleting appearance:multiline from many fields to see if it would fix the issue, the report template attached is the version before the deletes happened (I have attached XLSForm and report template (in full) with csv for pulldata reasons).
Any help would be greatly appreciated
Shwu-jingJeng
Hi James,
JamesBailey
Thanks heaps! Fixed my issue.
Shwu-jingJeng
Just to let you know that this is also documented on our doc that it's required to place multiline appearance on a dedicated line.
Feature report templates—Survey123 for ArcGIS | Documentation
