I am deploying surveys with ArcGIS Portal 10.4.1.
I can connect to my Portal and download surveys using iOS and Android Devices but when trying to connect using a Windows 10 mobile device, I can't add the connection to Portal.
Connecting to AGOL is OK.
Is there any known issue with that kind of device?
I use the latest version off Survey apps and build surveys with 1.9.24 build of Survey123 Connect.
Thanks in advance.
Emmanuel
Hi. First thing to check is that your Windows device can connect to your portal with a web browser. If that is the case, and you can successfully login to your Portal from a web browser, then it will be best that someone in Esri Technical Support looks at this issue. Would you please contact Tech Support. You can give them a call or submit an issue online. More details here: Esri Support Home
Thanks for your answer Ismael.
I can connect to my portal with all my devices. I will submit the issue to my local Esri technical support and report anything usefull in this discussion.
Emmanuel
My local support confirmed this issue. It is referenced as
BUG-000098853 : MOR_FCN: Survey123 for ArcGIS app shows keyboard over user input field in Portal page on Windows Mobile Phone.
Emmanuel
