Can't Access Web Survey Through IE/Edge
1051
07-25-2019 11:22 PM
LebogangMashishi2
I have created a Web Survey. ArcGIS Enterprise 10.5.1.
During testing i have noticed that most users cannot access that survey in Internet Explorer and Microsoft Edge.
We are using AD to log in. Once it logs users in it displays a message saying Survey is not accessible or is not available, despite the fact that i shared it to everyone in the organisation.
When users use Google Chrome, it works fine. But unfortunately the company policy is that users have to use IE/Edge as defualt browsers.
Can someone kindly assist with this?
Thanks in advance.
JordanMiller4
Try test loading the forms from somewhere outside of your company's network and see if that does the trick.
LebogangMashishi2
Unfortunately i cannot access our Portal for ArcGIS using a different network
JordanMiller4
Maybe see if your company has a VPN you can install on to your home PC for testing.
LebogangMashishi2
Great, will do so and revert back. Thank You so much
