I have a survey where I want to collect points for three locations: a driveway location, a well, and a chiller point which is similar to a well.
The analyze comes out good with only one non-critical suggestion, but I am getting this warning before publishing.
I understand that the chill_water is a table and needs to have a feature layer for the geometryPoint. Is only one geometryPoint allowed per form? The driveway location is the first point and I assume that it is collected initially on the map interface.
Does the warning meaning that the other two locations that I want to collect (well and chiller) are not collected?
I've read that more than one geopoint cannot be on a Survey123 form even though the form allows entry of more than one and the geopoint shows upon saving the form.
I went to the suggested ESRI page and tried searching for a simple answer but have not found a good explanation: Publish a survey—ArcGIS Survey123 | Documentation
Thanks for your help.
