I know this is an old post (at the link below), but I just wanted to check if this is still the case - that the spinner cannot be limited to positive values only? Thank you!
I found a possible solution while investigating calculations using XLSXForm.
Use the formula .>=0 and .<100 in the constraint field. If the user enters a value outside of the range 0-99 the question will be highlighted in red and the form cannot not be submitted - see the screenshots below.
Great, this worked! I did not want to limit the number that can be entered, so I only entered .>=0, which works fine for what I need. It still allows the spinner to go into negative numbers, but as you mentioned the form can't be submitted until that is corrected, so that will work fine. Thank you!
I am real happy it worked for you. You could add a statement in the hint field to remind users that negative numbers are not allowed. For example <div style=“font-style:italic; font-weight:bold; color:orange;”>Negative values will not be accepted</div>
Yes, I entered a constraint message that will prompt users to correct any negative numbers. Thanks again!
