Can same field name used in different layer/table in a survey?
58
10-11-2018 07:35 AM
MarkBennett
New Contributor III
I have a survey uses existing feature service and related tables (with repeats). some of the fields in feature layer and related table have same field name. The Survey Connect will give me a error for this situation. It seems it does not know which field to referring to when I used ${FieldName} in a Calculation. Is there anyway to name and refer a field in a specific feature layer or table, for example: ${tableName::fieldName}. Or do I have to use the unique field name in a survey?!
Ming
Reply
JamesTedrick
Esri Esteemed Contributor
Hi Ming,
You need to have unique field names across all tables in a form.
Reply
MarkBennett
New Contributor III
Thanks !
Get Outlook for Android<https://aka.ms/ghei36>
Reply
