Can I use instance_name with fields from a repeat table
331
03-22-2019 12:39 PM
Big_Sky_Ski_PatrolAdmin
I'm trying to update instance name for use in the inbox, etc.  It seems that I can't use fields a from a repeat.  They come out blank in the app.
concat("Dispatcher: ",${entered_by}," ID: ", ${eventid}, "First Responder: ", ${worker1})
Where eventid and worker1 are from the repeat table.
I don't find any reference to this in the help or in forums. Maybe I am missing something.
Philip Wilson‌ ??
Thank you,
-Ryan
JamesTedrick
Esri Esteemed Contributor
Hi Bob,
You can't use a question inside a repeat with the instance name directly.  You may be able to use it along with a join() function.  Another thing to keep in mind is that the default behavior of repeats in the Inbox is to not query any repeats - you would need to add the keyword `query` to the bind:esri:parameters column on the begin repeat line.
