Can i use answers from a previous multi-select as the options in a subsequent question?
825
04-25-2023 12:16 PM
Trippetoe
Hello. I am using the web designer to create my survey. I have a survey question that asks users to multi-select from about 15 or so application features. I then want to ask the question, "of the features selected above which do you use most often (select up to 2 features)".  Is it possible to populate the options of the second question with the options selected in the previous question?
Thank you
IsmaelChivite
Esri Notable Contributor
Not possible. Sorry.
IsmaelChivite
